Issue reading XML file
  • martin1b Offline
Post by martin1b »
I have an XML file saved from Excel. Trying to import it into a rowset to insert it into an iseries file. My test project (attached) treats each cell as a row, rather than the rows treated as a row. Any ideas what I'm doing wrong?
Here is my XML:
<project name="Read XML" mainModule="Main" version="2.0" logLevel="verbose">
		<xmlRead file="resource:smb://server1/Information Technology/Web/Temp/GA/test.xml" version="1.0">
			<rowset name="data" nestedSharedValues="true">
				<column index="1" value="/Workbook/Worksheet/Table/Row/Cell" name="lastName" />
				<column index="2" value="/Workbook/Worksheet/Table/Row/Cell" name="firstName" />
			</rowset>
		</xmlRead>
		<forEachLoop itemsVariable="${data}" currentItemVariable="item" currentIterationVariable="loopCount" disabled="false">
			<print version="1.0">
				<![CDATA[${item[1]}]]>
			</print>
		</forEachLoop>
test.xml
(4.07 KiB) Downloaded 1161 times
