CVE-2022-22963 Description
In Spring Cloud Function versions 3.1.6, 3.2.2 and older unsupported versions, when using routing functionality it is possible for a user to provide a specially crafted SpEL as a routing-expression that may result in remote code execution and access to local resources.
CVE-2022-22965 Description
A Spring MVC or Spring WebFlux application running on JDK 9+ may be vulnerable to remote code execution (RCE) via data binding. The specific exploit requires the application to run on Tomcat as a WAR deployment. If the application is deployed as a Spring Boot executable jar, i.e. the default, it is not vulnerable to the exploit. However, the nature of the vulnerability is more general, and there may be other ways to exploit it.
Developer Response
CVE-2022-22963 - This vulnerability does not apply to GoAnywhere products as we do not use Spring Cloud.
CVE-2022-22965 - The GoAnywhere products are not vulnerable to the issue addressed by CVE-2022-22965. This CVE is applicable to applications running on Java 9 or higher. Currently, GoAnywhere is only compatible with Java 8.
CVE-2022-22963 and CVE-2022-22965 - "Spring4Shell" Vulnerability Response
- Support_Jake Online
