How do I update Allowed Admin IPs for my MFTaaS Admin Gui webpage?
You can update the Allowed Admin IPs via our https://my.goanywhere.com/webclient/Login.xhtml portal.
GoAnywhere MFTaaS - all versions
To do this you will need to follow these steps:
1. Sign into the portal
2. Click on the “Cloud Environments” tab or navigate to the “GoAnywhere Cloud Hosted” section on this page.
3. Select the Hamburger icon next to your environment and then click “Manage”
4. On the “Manage Cloud Environment” page, refer to the "Allowed Admin IP's" section. Please read through our IP Filters description as it explains how to enter your IP addresses in CIDR notation. At this time, customers are only allowed 60 CIDR entries to be added to an environment filter.
5. For your new IP addresses range to take effect, you will need to click on the “Submit” button at the bottom of the page.
After clicking Submit:
7. Please wait a few minutes and then you can refresh this page. Once the changes are live, the Status will switch from “Pending” to “Active”
If you have questions about which IP addresses or ranges should be permitted, please consult with your Network Administrators. If there are additional questions after consulting with your Network Administrators, please to reach out to GoAnywhere Support.
