How to Pass Variables to IBMi
This is an example of how to pass a variable or value back to the IBMi from a GoAnywhere Director Project:
<project name="How to Pass data back to IBMi" mainModule="Main" version="2.0">
	<!-- Passed Parameters -->
	<variable name="UserName" value="" />
		<timestamp label="Create Timestamp Variable" version="1.0">
			<format outputVariable="Todays_Date" pattern="yyyy-MM-dd" />
			<format outputVariable="Two_Weeks_Ago" pattern="yyyy-MM-dd" dayOfMonth="-14" />
		</timestamp>
		<if label="Get UserName" condition="${ UserName eq &apos;&apos; }">
			<setVariable label="Set UserName" name="UserName" value="${system.user.name}" version="2.0" />
		</if>
		<exec400 label="Write Parms to DataArea" resourceId="Dev53" version="1.0">
			<command>
				<![CDATA[CRTDTAARA DTAARA(QGPL/GAPARMS)
                        TYPE(*CHAR)
                          LEN(250)
                        TEXT('Parameters from GoAnywhere')
				<monmsg messageID="CPF1023" action="continue" />
			</command>
			<command>
				<![CDATA[CHGDTAARA DTAARA(QGPL/GAPARMS (1 10)) VALUE('${UserName}')]]>
			</command>
			<command>
				<![CDATA[CHGDTAARA DTAARA(QGPL/GAPARMS (11 15)) VALUE('${Todays_Date}')]]>
			</command>
			<command>
				<![CDATA[CHGDTAARA DTAARA(QGPL/GAPARMS (26 15)) VALUE('${Two_Weeks_Ago}')]]>
			</command>
		</exec400>
Sr Support Analyst
