multiple instances of Goanywhere on same iSeries partition
  • sgoteti Offline
Post by sgoteti »
Can I set up multiple instances of Goanywhere on the same iseries machine. We have a development environment and test environment on the same machine and want to promote projects from development to test environment for testing. At the same time we want to keep the DB resource name common in the project so that it doesn't need to be edited in the environments. For eg: in the development environment DB resource "DBONE" should pickup the DEVLIB as the data library and in the test environment the same project with "DBONE" as the resource must point to the TESTLIB.
Thanks.
Re: multiple instances of Goanywhere on same iSeries partiti
More than one instance of GoAnywhere Director can be installed on your server.
When installing the second instance, you will need to specify a Library, IFS directory & ports that are not already in use by the other instance.
For other platforms, the install of the second instance would need to install to a different directory & port number as well.
You will need to contact your sales representative for a license key.
Sr Support Analyst
  • LPrendergast Offline
  • Verified User
Post by LPrendergast »
Hi, currently we arerunning GoAnywhere Director, Version 3.5.1 but would like to get to the 4.0 version. But due to SOX and IPO restrictions we cannot just upgrade with out testing soup to nuts,so we would likto install a second instance and parallel test. I notice fom the above thread that it is possible to install a second instance, but it would need a second lecense key. Are there any fees involved with his license key?
  • Verified User
When setting up a second instance of GA, is there a charge associated with the second license key?
Yes, there will be a charge associated with the second license. Please refer to your sales rep for additional information regarding this question. That email address is: [email protected]
Sr Support Analyst
