Using Variables in a GoAnywhere Project
A variable is a name associated with a value. In GoAnywhere, a variable can hold a variety of values including numbers, file and folder names, IP addresses and more. You can pass in the values for variables from your applications or from other projects.
Using a Variable to override a File Name
A project outline is shown below which connects to a SFTP server and puts a file onto that server. See Figures 1 & 2.
Figure 1.png (8.95 KiB) Viewed 9386 times
Notice how the Source File is hard coded with the file name of C:/temp/gademo.txt. This is not flexible if your file names change regularly.
Figure 2.png (16.77 KiB) Viewed 9386 times
Instead of using a hard-coded value, you can use a variable in the SFTP PUT task to supply the file name. To do this, right-click on the Project Level in the Outline and select “Add a Variable.” Give the variable a name, “MyFile” and leave the initial value blank (See Figures 3 & 4).
Figure 3.png (11.3 KiB) Viewed 9386 times
Figure 4.png (15.32 KiB) Viewed 9386 times
Your project outline now has the variable MyFile added.
Figure 5.png (11.5 KiB) Viewed 9386 times
You now need to add this variable to the PUT task Source File field. Variable names are wrapped with ${} when they are used as an input attribute in a task (See Figure 6).
Figure 6.png (24.21 KiB) Viewed 9386 times
With this change, you can now run the project and pass the name of the file you want to transfer.
Passing parameters can be done several ways:
  1. Interactively
  2. From another Project
  3. From a Monitor Job
  4. From a Scheduled Job
  5. From a GoAnywhere Services Trigger
  6. From an External application using the GACmd API
For this example, we will execute this project interactively and use our variable to pass the file path and name. Click on the Cog button next to the project name, and then click the “Execute Advanced…” option (see Figure 7).
Figure 7.png (31.01 KiB) Viewed 9386 times
This allows you to pass a value to the variable defined earlier within the project (see Figure 8).
Figure 8.png (18.75 KiB) Viewed 9386 times
By filling in the File Path and Name, then clicking on the “Execute” button, you can then view the job log to see where ${MyFile} is created and set to the value “C:\Temp\GADemo2.txt.” You can also see that the file has been uploaded successfully (see Figure 9).
Figure 9
Figure 9.png (252 KiB) Viewed 9386 times
The Source for this project is located below.
<project name="Using Variables - Part 2" mainModule="Main" version="2.0" logLevel="verbose">
<variable name="MyFile" value="" />
		<sftp label="Connect to Server" resourceId="Test SFTP" version="1.0">
			<put label="Put file on Target Server"
sourceFile="${MyFile}"
destinationDir="/Demos/inbound" />
		</sftp>
	<description>Basic Project with Parameter</description>
Please feel free to contact Fortra at [email protected] with any questions or to inquire about our Professional Services or Training programs.
Solution Architect
