Thank you for this little gem of a program.
Are there any ill-effects in usage if I import a key from external source having a length that is not listed by the program's key generator - e.g. 3072 bit long?
Please advise.
Using an external key of a different length
- Support_Jon Offline
Re: Using an external key of a different length
Hello krishna,
Although we don't offer creation of keys in the length in question (3072) you should be able to use keys created with this length within GoAnywhere OpenPGP Studio.
I created a new 3072 byte key and successfully used it to encrypt/decrypt without any issue.
If you're having using using a key of this length, please let us know the specifics on the key and what error you are seeing.
Thanks - Jon
Thanks - Jon
