I am using the ReadCSV task to process records from a downloaded file.
I use the Data feature in the ReadCSV task to specify and setup each column/index.
The first record on the file is a header record with 4 columns - I need to bypass this record. The remaining records are detail records with 256 columns.
I set the Skip First Row field on the ReadCSV task to TRUE, but either it's not working or I'm using it in an invalid manner.
The project execution blows up with the message Read Data File(s)] Invalid column index '5'. Input file contains only '4' columns. This is telling me that it's trying to process the first record which is the header record.
Am I attempting to use the Skip First Row value in a way other than what is was intended? I have attached the XML view of my project if this helps.
Skip first row?
Skip first row?
Re: Skip first row?
No matter whether you're reading or skipping the 1st row, it has to match up with the rest of the document. So, you either need to delete the first record (header row) or add a comma to make it think it has 5 columns (even if you skip that row based on configuration settings)
For the Read to work, even skipping the header rec, it has to match the rest of the doc.
Let me know if that helps!
- kgutierrez Offline
Re: Skip first row?
This is the exact issue I'm having right now. Is there a way to download and decrypt the file (which works fine) and then programmatically delete the first record out of the file before trying to read and insert into table? This is an issue with every file we download as they all have header records so need to figure out a way around this that doesn't involve a manual process.
