Combine Filelist
  • dchmax Offline
Combine Filelist
Post by dchmax »
I am calling a FTP get task, 2x+, and downloads the file(s) to the local workspace. I could just run a get filelist on the local workspace to get a complete list of all files. Wondering if I could merge the filelist output from each time the FTP Task is called into 1 list.
David
Re: Combine Filelist
At this time, the merging of the FileList isn't available. Your best bet here is to do a CreateFileList across your local WorkSpace once all files have been received to generate a single file list.
The only other option is that if you're retrieving all your files from the same FTP location, those can be added to the same FTP|Get filter.
For example:
		<ftp resourceId="DemoFTP" version="1.0">
			<get label="Get Files" destinationDir="${system.job.workspace}" whenFileExists="overwrite" destinationFilesVariable="MyLocFileList" numFilesDownloadedVariable="NoFiles" processedSourceFilesVariable="MyRmtFileList">
				<fileset dir="\My\First\Directory">
					<wildcardFilter>
						<include pattern="1st_Dir_Files*" />
					</wildcardFilter>
				</fileset>
				<fileset dir="\My\Second\Directory">
					<wildcardFilter>
						<include pattern="2nd_Dir_Files*" />
					</wildcardFilter>
				</fileset>
				<fileset dir="\My\Third\Directory">
					<wildcardFilter>
						<include pattern="3rd_Dir_Files*" />
					</wildcardFilter>
				</fileset>
			</get>
		</ftp>
Hope this helps!
  • dchmax Offline
Post by dchmax »
I will go with your 1st suggestion then. Thanks for your response.
David
