Calling GoAnywhere API via .Net Program
  • kgould Offline
Post by kgould »
The product documentation (http://www.goanywhere.com/products/dire ... mands-apis) sows that you can call GoAnywhere via a .Net program using a dll. I downloaded the client application and could not find any reference to the sample code or the dll to use in a .Net project.
Can someone point me to where I might be able to find the information.
From the product documentation on the web site:
Commands for .NET
GoAnywhere commands can be executed from .NET applications using the GoAnywhere
open source C# API. Included in the API is a sample Windows Form application for
demonstration purposes and to provide working code examples. Your .NET application
can reference the packaged DLL file or include the C# source code for further
customization.
Thank you,
Ken
Re: Calling GoAnywhere API via .Net Program
Ken,
I'm sending you the API in a separate email.
  • bmoyno Offline
Post by bmoyno »
Hi Rick,
Would it be possible to also be emailed the API?
Regards,
Brian
  • mattolsen Offline
Post by mattolsen »
Can I also receive a copy of this API?
Thank you
  • rivast_2001 Offline
Post by rivast_2001 »
We are in the process of automating the call of a GoAnywhere project hosted on the iSeries from a Windows server. Could it be possible to get a link to where the commands and APIs can be downloaded?
Thanks in advance.
Rivast,
All the documentation can be downloaded from your Customer Portal. Look into the Command Client (GACmd). The links are there for you to download the actual API for whatever OS you are using for free.
  • kenedy Offline
Post by kenedy »
Just follow Support_Rick 's comments and ideas.
Graduated from Soran University with First Class Degree with Honours in Computer Science.
  • cmayil Offline
Post by cmayil »
Could you please email me the C# API . I am unable to log in to my.goanywhere.com, Also I am unable to reset my password.
cmayil,
I'm not showing you as being registered on the Customer Portal with your current email address. Please register and setup your account through the Portal Registration, or contact [email protected] for further information.
