When testing a FTPS server definition, customer is getting a
"Server chose unsupported or disabled protocol: SSLv3" error
This issue is only noticed when GoAnywhere (prior to version 2.0) is installed on the iSeries. Upgrading GoAnywhere to version 2.0 will correct this problem.
In GoAnywhere 2.x or higher go to the FTPS resource definition and select SSL on the Security Protocol attribute on the Basic tab. Then enter SSL or SSL_TLS on the SSL Context Protocol attribute on the Advanced tab. Then press the TEST button & verify that it connects.
- Support_Julie Offline
