Hi
When I try to decrypt a file sent from a trading partner, I get an error message saying "java.io.EOFException: premature end of stream in PartialInputStream". I have successfully decrypted files from this trading partner before but I noticed when the row limit exceeds 22 rows in the spreadsheet, this error occurs.
I'm running version 1.0.1 on a Windows 7 machine.
Any help on this will be greatly appreciated. Thanks in advance.
Decryption Error
- Support_Jon Offline
Re: Decryption Error
Hello,
In some instances this error can occur if the encrypted data packet length is wrong. When this occurs, it typically points to an issue in the encryption process. I would recommend you bring this up with your trading partner and see if they can investigate this further.
Thanks - Jon
Thanks - Jon
