Session.connect: java.io.IOException: End of IO Stream Read
  • Rocky Offline
Post by Rocky »
We have a new error coming up I've never seen before. It is "Session.connect: java.io.IOException: End of IO Stream Read" What does this mean and what do I do to resolve this?
- Roc
Re: Session.connect: java.io.IOException: End of IO Stream R
Roc,
Need a bit more information on this ...
What are you doing to get this? Can we get the full job log? If it's in a Project, can we get the Project XML as well? Please run in Debug mode so we can get as much information as possible.
Thanks!
  • Rocky Offline
Post by Rocky »
Rick,
I have attached the project XML and two joblogs with this problem. Hopefully this will provide you with some useful clues. This is not my project so I can not go in and just change it over to Debug without talking to the project owner. I will try to do that and get back to you. As soon as I have a log in debug mode with this error I'll send it over.
In the meantime if you have any ideas please let me know. Thanks very much for your help.
- Roc
1380101034873.log
Here is another joblog, if this helps at all.
(6.85 KiB) Downloaded 971 times
1380101034865.log
Here is a job log. Not in debug mode - Sorry.
(6.85 KiB) Downloaded 815 times
