Error importing ASC key
I just installed the Studio and when I try to import a key I get an error "java.io.IOException:unknown object in stream: 21". I am using an XP machine. What could be causing that?
- Support_Jon Offline
Re: Error importing ASC key
Hello Libertydp,
Do you know with what tool the key was generated?
Although very rare, some utilities can produce improperly formatted headers within the key file that can cause issues with importing the key. It is usually related to incorrect carriage returns that some key generators produce that are not to standards.
If you'd like further assistance with this, we will need to take a look at your key and see if we can pinpoint the problem. Alternately, you can see if you are able adjust settings on the tool used to export that may clean it up.
Thanks - Jon
Thanks - Jon
I know this is a very old thread, but I recently ran into this same error.
I do not know how my external vendor created this file, but I attached it to this post hoping someone could tell me what needs to be changed so that I can import it into Go Anywhere
Thanks
jeff
Thanks
jeff
- Attachments
- Renkim Corporation orig.txt
- (1.61 KiB) Downloaded 1311 times
