How to cancel an Active Job that was stuck?
Post by Prashanthi Rao »
I am seeing the same job from so many days in the active jobs list.
I tried to cancel it, but it is not getting cancelled.
As this job got stucked, in the next schedules, the job is throwing an error.
The error is as follows;
Project 'ADP To Oracle GL' is defined as not thread safe and an instance with job number '1372869524078' is already running. Please wait for this job to finish and then try again.
The job number that was mentioned in the error is the one which is in the active jobs list from so many days.
Can somehelp me in this regard?
Thanks,
Prashanthi Rao.
Re: How to cancel an Active Job that was stuck?
Prashanthi,
Check the job log to make sure it has a "completed" at the end. If so, there there has to be some reason why it wasn't removed (unable to connect to DB, etc). Maybe check the System Job Log to see (around the same time as the end of job) for additional errors that might determine why this happened.
To remove this from the Active Job Queue, you will need to stop/restart your GADirector Service.
Concerning the Thread-Safe...
If the project being run Is/can be run as a thread-safe job, then, from the Project Level in the Control Tab, change the "Thread safe" to YES. This will allow Multiple versions of the same project to run at the same time.
BUT ONLY DO THIS IF YOU KNOW FOR SURE THAT THE PROJECT DOESN'T AFFECT OTHER PROJECTS RUNNING AT THE SAME TIME!
Thanks for the reply Rick.
Will you please let me know if we restart the GAD services, will it affect currently running jobs?
Prashanthi,
Anytime you stop/start GAD it will affect the current running jobs. You will need to plan this when you can have a window of opportunity to do a quick stop/start of the GAD Service. Shouldn't be more than 10-20 seconds of downtime. Please make sure that no other jobs are running at the time!
Rick,
Thanks for the Info.
The problem got resolved :)
  • hsb11788 Offline
Post by hsb11788 »
Why does canceling a job require a restart of the services? I'm curious because we've had this issue since we upgraded to MFT, we know the workaround now for those resources that wouldn't connect, but prior to the upgrade, clicking the cancel icon would actually cancel the job.
