Running two instances of project at the same time
By default, a project can only have one instance running at a time. If you try to kick off a project that already has an instance running you will receive an error. The error message will look like "Project 'Test Project' is defined as not thread safe and an instance with job number '1223344556677' is already running". You may also see this error message "MSG GAE9898" if you tried to execute the project using the RunProject command.
If you would like to run multiple instances of this project simultaneously please follow the steps below:
1) Login into the GoAnywhere client and edit the project.
2) With the project node selected in the Project Outline (this is selected by default when you click on the edit button for a project) click on the Advanced tab.
3) Change the thread-safe option to "true".
The Thread-Safe option will specify whether or not it is safe to run multiple instances of this project simultaneously. The default value is false. A value of false ensures that only one instance of the project is active at any given time.
Support Team Lead
w. Fortra.com
Re: Running two instances of project at the same time
To add to this issue, there are instances where multiple iterations of a Thread-Safe Project need to run and are triggered back to back. I ran across this several times and was given the "Cannot run, Project is not thread-safe" error message. But, I still needed the 2nd job to execute after the first was completed. So, I came up with the following Project Codes that I use in a "Utility" fashion.
In this case, I chose to give the process 20 - 10 Second Delays before timing out. This gave me a controllable Front-End to my Projects to trap the Thread-Safe Errors and Still be able to end normally or submit the job with a sufficient amount of wait time.
<project name="Run Project" mainModule="Main" version="1.0" threadSafe="true" logLevel="debug">
  <!-- Parms Passed -->
	<variable name="pFolder"  value=" " description="Project Folder" />
	<variable name="pProject" value=" " description="Project Name" />
  <module name="Main" dependsOn="Check Parms,Check Status,Run Project">
    <print label="Status - Successful" version="1.0" executeOnlyIf="'${CheckJob}' eq 'Yes'">
      <![CDATA[
* "${pFolder}/${pProject}" Active?  ${pActive}
* No/Tries:  ${Tries}
    </print>
    <print label="Status - UnSuccessful" version="1.0" executeOnlyIf="( '${CheckJob}' eq 'Yes' ) and ( ${Tries} gt 10 )">
      <![CDATA[
* Run Job Unsuccessful - Number of Retries exceeded!
    </print>
    <print label="Status - Invalid Parms" version="1.0" executeOnlyIf="'${CheckJob}' eq 'No'">
      <![CDATA[
* Invalid Parameters Passed:
*     Folder:   ${pFolder}
*     Project:  ${pProject}
    </print>
  <module name="Check Parms">
    <setVariable label="Set CheckJob"     version="1.0" name="CheckJob" value="Yes" />
    <setVariable label="Check for Blanks" version="1.0" name="CheckJob" value="No" executeOnlyIf="( '${pFolder}' eq ' ' ) or ( '${pProject}' eq ' ' )"/>
    <setVariable label="Check for Null"   version="1.0" name="CheckJob" value="No" executeOnlyIf="( '${pFolder}' eq '' )  or ( '${pProject}' eq ''  )"/>
  <module name="Check Status" executeOnlyIf="'${CheckJob}' eq 'Yes'" >
		<setVariable label="Set Active" version="1.0" name="Active" value="No" />
		<setVariable label="Set Tries"  version="1.0" name="Tries"  value="1" />
    <forLoop label="Check Project Status" beginIndex="1" endIndex="20" step="1" currentIterationVariable="Tries" >
      <callProject label="Get Project Status" version="1.0" project="/Utilities/Get Project Status" inheritUserVariables="true" returnUserVariables="true" >
  			<variable name="pFolder"  value="${pFolder}"  />
  			<variable name="pProject" value="${pProject}" />
  			<variable name="pActive"  value=" " />
  		</callProject>
      <setVariable label="Set Active" version="1.0" name="Active" value="${pActive}" />
      <exitLoop condition="'${Active}' eq 'No'" />
      <delay label="Try Delay" version="1.0" time="${Delay}" timeUnit="seconds" />
      <setVariable label="Set Error"    version="1.0" name="Error"    value="0" />
      <setVariable label="Set SubError" version="1.0" name="SubError" value="0" />
    </forLoop>
  <module name="Run Project" executeOnlyIf="'${Active}' eq 'No'">
    <callProject label="Submit Job" project="/${pFolder}/${pProject}" runInSameJob="false" mode="batch" version="1.0" />
	<variable name="Delay" value="10" description="Amount of Delay in Seconds" />
	<description>Run Project checking for Thread-Safe</description>
<project name="Get Project Status" mainModule="Main" version="1.0" threadSafe="true" logLevel="debug">
	<variable name="pActive"  value=" " description="Return Value - (Yes) or (No)" />
  <module name="Main" dependsOn="Check Parms,Check Project">
      <![CDATA[
    </print>
      <![CDATA[
    </print>
  <module name="Check Project" executeOnlyIf="'${CheckJob}' eq 'Yes'" >
    <sql label="Check GADerby" resourceId="GADerby" version="1.0" onError="setVariable:SubError=2" >
      <query label="See if Active" outputVariable="OutPut" whenNoDataFound="error">
        <statement>
Select Count( * )
  From APP.DPA_JOB
 Where Proj_Folder = &apos;/${pFolder}&apos;
   and Proj_Name   = &apos;${pProject}&apos;
   and Status      = &apos;A&apos;
        </statement>
      </query>
    </sql>
    <setVariable label="Set pActive" name="pActive" value="No"  version="1.0" executeOnlyIf="( ${SubError} gt 0 ) or ( ${OutPut[1]} eq 0 )"/>
    <setVariable label="Set pActive" name="pActive" value="Yes" version="1.0" executeOnlyIf="${OutPut[1]} gt 0"/>
	<description>Get Project Status</description>
Solution Architect
