Projects are stored in an XML format inside of GoAnywhere. The examples you see in this forum may be complete projects or snippets of a project XML. If you would like to run one of these projects there are a few ways you can load the projects into your GoAnywhere system.
If you have the complete XML the easiest way to use the project is to import the project.
- Sign into GoAnywhere
- Click on the Projects menu
- Click on the Import Project button
- Specify the file that contains the Project XML
- Edit the project to meet your needs
- Click on the pencil icon to edit a project
- Click on the Show XML button
- Paste a snippet stored in your clipboard or edit the XML accordingly
