Issue with IF function
If you need a quicker response, please create a support ticket via the customer portal my.goanywhere.com or contact our support team by email at [email protected].
  • dhascup Offline
Post by dhascup »
My IF function is not working properly
In the productType "CA" comes out as it should
In the packagingType "PK" comes out when it should be "CT"
They both refer to dataItem[7]
<element name="globalAttributes">
									<element name="productType" value="${dataItem[7]}" trim="both" />
									<element name="globalClassificationCategory" trim="both">
										<element name="code" value="${dataItem[58]}" trim="both" />
									</element>
									<element name="gtinName" value="${dataItem[9]}" trim="both">
										<attribute name="lang" value="en" trim="both" />
									</element>
									<element name="brandName" value="${dataItem[5]}" trim="both" />
									<element name="brandOwnerGLN" value="${dataItem[6]}" />
									<forEach inputRowSetVariable="${dataNetContent}">
										<if test="${dataNetContent[1]} eq ${dataItem[2]}">
											<if test="${dataNetContent[2]} eq ${dataItem[3]}">
												<element name="netContent" value="${dataNetContent[3]}" trim="both">
													<attribute name="uom" value="${dataNetContent[4]}" trim="both" />
												</element>
											</if>
										</if>
									</forEach>
									<element name="packagingType" trim="both">
										<element name="code" value="${If((dataItem[7] == "CA"), "CT", "PK")}" trim="both" />
									</element>
See attachment for captured result
Thanks
David
Re: Issue with IF function
Dave,
More than likely there are some spaces in the data. Please review and/or remove them and let me know.
Thanks!
