Hi,
I'm sure this is real easy to see but I can't see the issue.
In the job log I see
"ERROR [8098 - Write Detail] /Accounting/NEVADA DAIRY COMMISSION BUTTERFAT TAX 080116.xlsx (A file or directory in the path name does not exist.) "
I confirmed that the folder /linoma/goanywhere/userdata/documents/accounting does exist. Is the an issue with the file name? I can't see it.
Thanks,
Rob
- rarogerson Offline
- ChrisHiebert Offline
Re: A file or directory in the path name does not exist.
I believe you need to prepend the system.docroot onto the the start of the file path. Otherwise it is attempting to pull from the root of the file system.
<setVariable label="Set filename to process"
name="filename" value="${trim(system.docroot)}/Accounting/NEVADA DAIRY COMMISSION BUTTERFAT TAX 080116.xlsx"
version="2.0"/>
