Hi,
on the Web GUI there is an option to export All Web Users as .xml. I tried to do the same with the following command: "gacmd.exe -server Server -user User -password xxx -command exportWebUser -userName * -webUserOutputFile C:\"
But this is only working if I Specify a User Name. Is there a way so export All Users with gacmd? If not is there any other way to accomplish this task?
Export All WebUsers
Re: Export All WebUsers
Lorenz,
You can put your Web Users into a Web User Group then export the Web User Group as a whole, but using a wildcard like "*" doesn't work for all. This could be an Enhancement Request to add to the product for a future release though.
Otherwise, the only other way would be to loop through the list of Web Users and perform an export for each.
Contact [email protected] and request an Enhancement Request form to get this submitted.
