importing xml into excel
For questions and information regarding GoAnywhere MFT.
Feel free to share ideas, workflows or other best practices with other users.
Forum rules
If you have a support request, please raise a support ticket via the customer portal my.goanywhere.com or contact our support team by email at [email protected].
I am trying to read an XML file and write it to excel. When I do I get the following log and the job bombs. Any help would be appreciated.
Re: importing xml into excel
Check the paths for your XML data. They must match exactly (including case).
I did check that for most of the path I use a resource so that would be correct and I double checked the folder and that is spelled correctly. I even copied the name of the folder from the folder to the go anywhere task and still does not work.
Please send a copy of your project XML and the full DEBUG joblog to [email protected] for additional assistance.
I am able to load XML into excel but one record is being written to 3 rows which may be a function of excel more that go anywhere
