database- job log files or table
If you need a quicker response, please create a support ticket via the customer portal my.goanywhere.com or contact our support team by email at [email protected].
  • ernguyen Offline
Post by ernguyen »
Hey guys- We are currently using the native local Derby database for GOAnywhere MFT. If we migrate to an Oracle or SQLServer instance, will the job logs be stored in tables or will they remain as log files on the local system?
Re: database- job log files or table
It depends ...
Job logs are originally created and utilized within your database. This makes them researchable. So, if you move it to Oracle, they will go with them. Additional logs (System, etc) are kept in the default logs folder location. When the archive point is reached, then logs can be written to your default log location in an archive folder, if desired.
