When i try to execute by command line, it return next error:
ERROR Error connecting to 'https://x.x.xx.xx:xxxx/goanywhere': peer not authenticated
ERROR peer not authenticated
mssing something certificate in my local machine ?
Line to execute is:
gacmd.exe -server https://x.x.xx.xx:xxxx/goanywhere -user fusme -password ******** -command runProject -Project /Capacitacion/Prueba_FAusto
Please help.
Thanks a lot
Re: ERROR peer not authenticated
What this means is ... the server doesn't trust you using an HTTPS command. (Ie, the server doesn't posses the correct SSL Certificate from the client)
Add the SSL Certificate to the Trusted Certificates Key Store. Also, review the other parameters to the GACMD call. "trustAll", etc)
If not necessary to use HTTPS, you could do this as HTTP and execute as well.
