Installation Guides with demonstrations
If you need a quicker response, please create a support ticket via the customer portal my.goanywhere.com or contact our support team by email at [email protected].
  • ashford Offline
Post by ashford »
HI
I am having difficultly in setting up my MFT server and my gateway server.
the first problem i am experiencing is when the MFT server connects to the Gateway server I get this error on the status of proxies
/128.16.8.10:443 - Inactive: Failed to bind to: /128.16.8.10:443 (please note these are not the correct IPs as I have changed them)
The Second is that I can only connect to the MFT server locally, im guessing its to do with the Listener settings on the HTTPS config, but I am unsure how to configure it correctly as there are no demos I can look at.
Any Help with these errors or some walk through guides would be great
Thank you
Re: Installation Guides with demonstrations
Please refer to the installation guide for installing the Gateway. It will show you the firewall rules needed to make this communication happen.
In a nutshell, you only need OUTBOUND ports 9100, 9101 from your MFT server to your GATEWAY server open.
Make sure you have nothing utilizing ports 21, 22, 443 and 990 on your GATEWAY server
If you are using the same ports on your MFT server, make sure they are not being used by another program.
Then, under the Gateway Configuration, just map the GAG:IP/Port to the MFT:IP/Port
Also, do not forget to make sure your Gateway License is installed properly on your Gateway server.
