I'm trying to access the Web Client using HTTPS. I'm able to access the administration through HTTP but when I create a web user and try to access the web client I get an invalid username/password. I also get the following in the log.
05/12/16 2:56:02 PM ERROR An error occurred while processing the request URI '/webclient/Login.xhtml' from the ip address '10.200.8.252'. The HTTP status code is '500'
05/12/16 2:56:02 PM ERROR /webclient/Login.xhtml - No saved view state could be found for the view identifier: /webclient/Login.xhtml
javax.faces.application.ViewExpiredException: /webclient/Login.xhtml - No saved view state could be found for the view identifier: /webclient/Login.xhtml
at org.apache.myfaces.lifecycle.RestoreViewExecutor.execute(RestoreViewExecutor.java:183)
at org.apache.myfaces.lifecycle.LifecycleImpl.executePhase(LifecycleImpl.java:196)
at org.apache.myfaces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:143)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:198)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at com.linoma.ga.core.upload.FileUploadFilter.doFilter(Unknown Source)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at com.linoma.ga.ui.wc.application.ForwardingFilter.doFilter(Unknown Source)
at com.linoma.ga.ui.wc.application.WebClientSecurityFilter.doFilter(Unknown Source)
at com.linoma.ga.ui.core.filter.IFrameEmbeddingFilter.doFilter(Unknown Source)
at com.linoma.ga.ui.core.filter.NoCacheFilter.doFilter(Unknown Source)
at com.linoma.ga.ui.core.filter.IECompatibilityModeFilter.doFilter(Unknown Source)
at com.linoma.ga.ui.wc.application.RedirectFilter.doFilter(Unknown Source)
at com.linoma.ga.ui.wc.application.CharacterEncodingFilter.doFilter(Unknown Source)
at com.linoma.ga.ui.wc.application.ActiveSessionAddressFilter.doFilter(Unknown Source)
at com.ocpsoft.pretty.PrettyFilter.doFilter(PrettyFilter.java:118)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:503)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at com.linoma.dpa.services.GHTTPSIpFilter.invoke(Unknown Source)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:421)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1070)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:611)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:314)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Any thoughts?
Thanks,
Jonathan
Web Client
Re: Web Client
Jonathan,
Please contact [email protected] and request some help direct with the office for this.
Thanks!
Thanks!
