Regex Negation
  • Support_Josh Offline
Regex Negation
Post by Support_Josh »
Does GoAnywhere support regex negation? (The symbol ^ in a regex expression)
Yes, GoAnywhere supports regex negation even when using monitors. This functionality can be handy when using a monitor since the monitor itself cannot be set to exclude a set of files, you can use a regex expression to select the files you don't want to include and then negate the expression.
Example:
I want to monitor a folder for all files existing that don't start with error*.*
File List:
test.txt
error.txt
error1.txt
error2.txt
goanywhere.log
catalina.out
Working Regex Expression:
^(?!error).*
NOTE: The above expression will select all entries that start with the word error and then return the opposite.
Output List:
test.txt
goanywhere.log
catalina.out
Joshua Przybysz
Senior Support Analyst
