Entry repeating in tomcat logs "Kerberos username [username]"
  • Support_Josh Offline
Post by Support_Josh »
Repeated “Kerberos username [username]” entries appearing in logs.Kerberos username [username]".
Snippet:  Kerberos username [username]: Kerberos username [username]: Kerberos username [username]: Kerberos username [username]: Kerberos username [username]: Kerberos username [username]: Kerberos username [username]: Kerberos username [username]: Kerberos username [username]: Kerberos username [username]: Kerberos username [username]: Kerberos username [username]: Kerberos username [username]: Kerberos username [username]: Kerberos username [username]: Kerberos username [username]: Kerberos username [username]: Kerberos username [username]: Kerberos username
GoAnywhere MFT - Linux
That entry is being generated from the SFTP Authentication method gssapi_with_mic. When it is supported by the server and GoAnywhere MFT has not explicitly disabled it, it may be chosen for authentication against the server which can produce the log entry "Kerberos username [username]" where [username] is the user starting GoAnywhere.
To resolve this, look for SSH servers that are being used repeatedly, most likely used on a Scheduler or a Monitor. Once you have tracked down repeating SSH connections, edit the problematic resource by navigating to Resources > SSH Servers page. Then inside the resource, navigate to the Algorithms tab and select all other algorithms except gssapi_with_mic and move them to the Selected column.
After editing, save the resource and exit. The next time the SSH connection happens, GoAnywhere won't attempt to use the gssapi_with_mic authentication method thus not producing the line.
Repeat for all SSH connections that are producing the log entry.
Joshua Przybysz
Senior Support Analyst
