ERROR A problem occurred while trying to parse the directory listing into a list of remote files
When testing a resource I receive the error that I'm unable to parse the directory. What can I do to resolve this?
list error.png (31.58 KiB) Viewed 21026 times
The list parser needs to be modified. By default GoAnywhere uses a Unix parser. When switched to the correct parser you will be able to traverse all sub directories.
list parser.png (22.25 KiB) Viewed 21026 times
