How to retrieve a GoAnywhere error from an iSeries CL
On the iSeries, we have a CL that calls a GoAnywhere project. If an error is raised in the GoAnywhere project, how can the CL retrieve that error?
The following example allows you to specify your errors with the Raise Error task and retrieve those in the calling CL.
Sample Project:
<project name="Test" mainModule="Main" version="2.0" logLevel="verbose">
		<createFileList numFilesFoundVariable="FileCount" version="1.0">
			<fileset dir="/temp" />
		</createFileList>
		<if condition="${FileCount==0}">
			<raiseError version="1.0">
				<message>WAS1001 - Unexpected error!</message>
			</raiseError>
		</if>
Sample CL:
             PGM
             DCL        VAR(&MSG) TYPE(*CHAR) LEN(100)
             DCL        VAR(&MSGID) TYPE(*CHAR) LEN(7)
             DCL        VAR(&GAMSGID) TYPE(*CHAR) LEN(7)
             DCL        VAR(&LOWKEY) TYPE(*CHAR) LEN(4)
             DCL        VAR(&HIKEY) TYPE(*CHAR) LEN(4)
             DCL        VAR(&MSGKEY) TYPE(*CHAR) LEN(4)
             DCL        VAR(&ERROR) TYPE(*CHAR) LEN(5) VALUE('NO')
             /* Send a message so we can capture the low key value for later.   */
             SNDPGMMSG  MSG('Preparing to RUNPROJECT') TOPGMQ(*SAME) +
                          KEYVAR(&LOWKEY)
             RMVMSG MSGKEY(&LOWKEY)
             RUNPROJECT PROJECT('/Test')
             MONMSG     MSGID(GAE1002) EXEC(DO)
                 CHGVAR VAR(&ERROR) VALUE('YES')
             ENDDO
             /* Send a message so we can capture the high key value for later.   */
             SNDPGMMSG  MSG('RUNPROJECT complete') TOPGMQ(*SAME) +
                          KEYVAR(&HIKEY)
             RMVMSG MSGKEY(&HIKEY)
             IF  COND(&ERROR *EQ 'YES') THEN(DO)
                 /* LOOP TO RECEIVE MESSAGES WITH RCVMSG COMMAND                    */
                 CHGVAR %BIN(&MSGKEY 1 4)  (%BIN(&LOWKEY 1 4) + 1)
                 LOOP:
                 RCVMSG     PGMQ(*SAME (*)) MSGKEY(&MSGKEY) RMV(*NO) +
                          MSG(&MSG) MSGID(&MSGID)
                 MONMSG CPF2410 EXEC(DO) /* HANDLE MSGKEY NOT FOUND                 */
                   RCVMSG     MSGTYPE(*EXCP) RMV(*YES) /* REMOVE UNWANTED EXCEPTION */
                   GOTO       SKIP
                 ENDDO
                 IF  COND(&MSGID *EQ 'GAE9898') THEN(DO)
                     /* Parse out return from &MSG */
                     CHGVAR VAR(&GAMSGID) VALUE(%SST(&MSG 22 7))
                     /* [9001 - Raise Error] WAS1001 - Unexpected error!   */
                     /* 12345678901234567890123456789012345678901234567890 */
                 ENDDO
                 SKIP:
                 CHGVAR %BIN(&MSGKEY 1 4)  (%BIN(&MSGKEY 1 4) + 1)
                 IF (&MSGKEY *LT &HIKEY) GOTO LOOP
             ENDDO
Support Team Lead
w. Fortra.com
