How to configure the WRITE task after a SQL query so that custom column headings are written to the file as opposed to the field name
If you wish to specify a column heading other than the field name, then you need to specify the column heading in the SQL statement.
You can use the SQL Wizard in MFT to build the SQL. If you select “Custom Heading”, then it lets you add whatever you want for the field heading.
Otherwise, you can modify your SQL statement by adding the AS “custom heading” syntax to the SQL for each field.
Then you can use that Output variable in a subsequent Write task (CSV below) and specify "includeHeadings="true".
For Example:
SELECT
field1 AS “Custom heading 1”,
field2 AS “Custom heading 2”
FROM
DatabaseTableNameProject example:
<project name="CustomHeadingsExample" mainModule="Main" version="2.0" logLevel="verbose">
<sql resourceId="MyDatabaseServer" version="1.0">
<query outputVariable="data">
<statement>
SELECT
FROM
DatabaseTableName
</statement>
</query>
</sql>
<writeCSV inputRowSetVariable="${data}" outputFile="\temp\MyFile.csv" includeHeadings="true" version="1.0" />
