Gateway Version/License check
Display GoAnywhere Gateway's Version
Perform the following steps to display the installed version of GoAnywhere Gateway:
  1. Open a Command window or Terminal.
  2. Change the directory to the installation directory.
  3. Run the command ./gagateway version
or
  1. Open up the .swidtag file located in the the [Gateway Install Dir]/GoAnywhere Gateway/swidtag folder. You will see version="x.x.x"
Display the License Information
Perform the following steps to display the license information:
  3. Run the command ./gagateway license. If a license is already installed, the license
    information will be displayed on screen
Windows Example
Installation Directory: C:\Program Files\HelpSystems\GoAnywhere Gateway
License File Location: C:\Program Files\HelpSystems\GoAnywhere Gateway\gateway.lic
Linux/Unix Example
Installation Directory: /usr/local/HelpSystems/GoAnywhere_Gateway
License File Location: /usr/local/HelpSystems/GoAnywhere_Gateway/gateway.lic
