A newly Configured REST Server resource fails with 400 or “It is not on the appropriate screen or unknown” error
In some older versions of REST server implementations, authentication is transmitted preemptively opposed to when a client connects to the server, and the server asks the client to login. In this scenario, the REST server requires authentication to occur in a request header upon connection.
In order to fulfill this requirement, a Request Header element can be added to the REST (post, Get, Put, etc.) command task. The Name value should be Authorization with a Value of Basic (base 64 encoded string for username:password) PLEASE NOTE, this does not include the brackets from the following image, it should be "Basic string value" where string value represents the base 64 encoded string of username:password.
