I am setting up a new Windows installation of GoAnywhere MFT/GoAnywhere Gateway.   The service ends after being up for a few seconds.  In my Tomcat log I see the error:  Cannot assign requested address: JVM_Bind. How do I resolve this?
This error indicates that the address or port specified is unable to be used. This can occur due to an incorrect IP configuration for GoAnywhere or the port not being available. One way you can resolve this issue is by checking the HOST table to see if you are pointing the localhost address to an IP other than the IP of the server GoAnywhere was installed on. This this can occur when the server is a cloned VM server & has a static IP.
Additionally, you should verify whether the Port is already in use. If the port is already in use, you will need to investigate with your networking team to identify which port should be used.
							ERROR Cannot assign requested address: JVM_Bind
- Support_Jake Offline
+1 402.944.4242 fortra.com
