The default user, password, and URL (GoAnywhere server address) for GoAnywhere MFT can be modified.
GoAnywhere MFT - IBM i
To change the GoAnywhere MFT default user, password, and URL (the GoAnywhere server to connect to), run the command GOANYWHERE/CFGGA.
Choose option 2 for the items that you would like to change, enter the new value and save it.
Then, save the settings and restart GoAnywhere by running the STRGA command.
Changing the default user id and password on iSeries?
- Support_Julie Offline
