Q.
GoAnywhere was installed successfully. Now when we start GoAnywhere (GOANYWHERE/STRGA) we receive an error:
Value specified for USER parameter not correct.
Error found on CHGJOBD command.
CPF0001 received by procedure STRGA. (C D I R)
A.
There are certain user profiles that you cannot use to start the GoAnywhere subsystem.
These are 'QSECOFR', ‘QSPL', 'QDOC', 'QDBSHR', 'QRJE', 'QSYS', 'QLPAUTO', 'QLPINSTALL', 'QTSTRQS' Or 'QDFTOWN'
Please try a different User Profile when running the STRGA command
We suggest that you use the QPGMR user profile. This is only a suggestion, not a requirement.
- Support_Julie Offline
