Change authorities on IFS directories
There are two ways to change the authorities to the IFS directories.
1. Use the QSH command chmod –R 777 * command
2. Use WRKLNK
Take option 9 next to the object to display the authority
Then option 2 next to the object to change the authority
In Version V5R4M0 and higher there is also an option “Directory subtree” to allow you to change all objects in subdirectories.
Support Team Lead
w. Fortra.com
